-   -   Y+ and negative cell volume (http://www.cfd-online.com/Forums/fluent/43203-y-negative-cell-volume.html)
Ashok kumar December 26, 2006 07:41
Can anyone give me a clear definition on y+ and negative cell volume.
Ashok
hugo December 26, 2006 19:03
Re: Y+ and negative cell volume
y+ is the adimensional normal distance from de wall
y+ = f(rho, mu, tao_w, y)
rho, density (kg/m^3) mu, viscosity (kg/s*m) tao_w, shear strain in the wall (kg/s^2*m) y , normal distance from de wall (m)
y+ = sqrt(rho*tao_w)*y/mu
for example the transition from de sub-viscous layer to the logaritmic velocity profile near the wall is when y+ is near 11
if you want to define the sub-viscous layer you need y+ for the first node close 1,
if you want to use wall function, maybe with y+ for the first node close to 20 is ok
A negative cell volume is not good, you need to check the mesh, I don't now how fluent calculate the negative volume but I sure that it's wrong.
good luck happy new year
