Home > Forums > FLUENT
Error in Gambit
Old   January 8, 2007, 06:37
Default Error in Gambit
Wilson
In Gambit, when I am trying to convert surface mesh to solid mesh, it gives me error
- Initialization failed; perturb boundary nodes and try again
I tried all kinds of interval size, I cant able fix this problem. Can anybody help me on this?
More over I don't T-Grid software to convert surface mesh to solid mesh.
Old   January 9, 2007, 05:32
Default Re: Error in Gambit
Pratik
check the skewness of the surface mesh.. this generally is the problem... if the geometry is complicated, you can chk if regions with small gaps have adequate mesh density!!
Old   January 9, 2007, 05:35
Wilson
Thanks Pratik
What is the range of Skewness value we are supposed to have in the surface mesh? How to check the same in Gambit?
Thread Tools
Trackbacks are On
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 09:33
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 04:10
