simulate reverse flow for filter cleaning
Old   January 6, 2007, 01:14
Default simulate reverse flow for filter cleaning
Rashmi
Hi
does anyone know how to simulate reverse flow in fluent. the veleocity should be in reverse direction to reveome the cake deposit/to clean the filter..
Thnx
Old   January 9, 2007, 04:35
Default Re: simulate reverse flow for filter cleaning
Pratik
you may try this... use a pressure outlet BC and manipulate the back-pressure for flow reversal!
Old   January 13, 2007, 06:38
Rashmi
Hi thx for your reply.
i didnt get what do u mean by manupulate the pressure in outlet BC. the ceramic filter has one open end and one closed end. from the previous exp results i see that the pressure is almost zero near open end and maximum (approx 5000 pa) at closed end..
in my geometry the pressure outlet BC is open end..so should i enter max pressure here??
thx
Reverse flow e101533 Siemens 9 April 5, 2020 02:29
CAN'T CONVERGE WITH REVERSE FLOW AT OUTLET! XIAOYI LI FLUENT 11 September 14, 2012 16:43
CFDesign V11 -- Reverse flow at outlet maruthiv Autodesk Simulation CFD 1 June 17, 2011 09:38
Flow simulation in reverse drum mixer Patel Chirag CFX 0 July 19, 2010 15:05
reverse flow someshwar rao FLUENT 3 March 9, 2007 03:35
