Home > Forums > FLUENT
turbulence
Old   January 9, 2007, 09:05
Default turbulence
David
I want to plot rms velocity plots for turbulenct channel flow. At what part of the channel should i plot this data. I have been told to plot the data on a line cutting through the centre of the domain, is this correct??
Old   January 9, 2007, 09:23
Default Re: turbulence
hugo
If you are using an straight channel with circular cross section, it's OK because the solution is axisimetric.
good luck
Old   January 9, 2007, 09:24
David
Its a straight rectangular section with periodic boundaries in stream and spanwise directions. Is that ok?
Old   January 9, 2007, 10:17
hugo
David, I don't undestand the periodic boundary in spanwise direction. Is an open channel with cross flow?
Sorry, I was confused about you first question, because i was thinking about a circular straight close channel and to plot the rms velocity in a line inside a cross section.
But I think you should plor the rms velocity in a cross section
Thread Tools
Trackbacks are On
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 05:30
Turbulence postprocessing Mohsin FLUENT 0 September 19, 2011 21:05
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 17:15
