January 9, 2007, 09:43 |
free flow problem
Hi everyone!
I've got a simple (?) 3d-question: I'm going to examine the wind field over a mountain ridge... But I'm not sure about what B.C.s I should choose. Should I expect convergence problems if I define the surrounding (west, east, north and south) boundaries as v_inlets? I was thinking about v_inlets to have the ability to vary the direction of the wind with each time step. For the top boundary ("heaven") I was thinking about a symmetry, but a collegue told me that this would cause big convergence problems. Can anyone of you give me a hint about how to choose my B.C.s? Thanks, Thomas |
January 10, 2007, 09:02 |
Re: free flow problem
Isn't here really nobody out there who can help me?? Please!!!
January 11, 2007, 10:04 |
So because of the lack of comments to my original posting, I am going to test it with different B.C.s... I'm also going to comment them here, so if you've got suggestions, feel free to leave a posting ;-)
My first attempt was using a pressure-f-f for the surrounding boundaries, unfortunately my domain is about 6x6x10km (LxWxH) and I need fine resolution. Therefore p-f-f seems to be not well suited for this (I already have about 1 million elements and I am pretty limited what concerns computational resources) because of the FAR field thing. Although, the p-f-f seems not to be compatible with my multiphase mixture model, because it requires the coupled solver (which is not supported my m-m-m, according to the fluent user manual). So the 4-times-v_inlet idea came into my mind... so that's the point where I got stuck right now... Hints, suggestions... are welcome. thanks, thomas |
January 11, 2007, 13:10 |
I'd neglect time varying velocity conditions at the boundary unless you have a lot of time to wait for the model to run. Apply velocity magnitude at 3 of the boundaries far from the area of interest, closer if you know the profile and can map to the boundary. Make sure the flux across these boundaries sums to a reasonable level for the remaining boundary. Use an outlet or pressure boundary at the downstream boundary. If there are convergence problems due to recirculation, consider decreasing the open boundary area.
Display Modes | |
Boundary condition problem for open channel flow | Andy | CFX | 9 | June 11, 2016 08:20 |
Convergence but incorrect results in Free Surface flow | fmjb | CFX | 10 | October 26, 2011 08:18 |
Problem Concerning free surface wave simulation | michaels | STAR-CCM+ | 3 | February 25, 2011 08:28 |
transient compressible flow problem (urgent plz) | jehanzeb | FLUENT | 5 | August 3, 2004 09:04 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
