-   -   why enthalpy residual is great ??? (http://www.cfd-online.com/Forums/fluent/43279-why-enthalpy-residual-great.html)
Asghari January 9, 2007 12:43
Hi CFD specialists ;
I am working on two phase flow with mass transfer process;I need to check following expression for computing residual of energy equation without energy source term in steady state. ( div.[ rho U (E+p/rho)] -div.[k (grad (T))]=0.0 (k is effective conductivity)
Fluent uses finite volume method for discretization of left hand side of upper equation according to the following form :
S= [(sigma on faces) {rho U.dA (E+p/rho)}-(sigma on faces ) { k grad(T).dA}]/ cell volume
In single phase flow without energy source term , S should be zero. I use from a udf in order to certify this object , Udf computes right hand side of upper equation ( S); The part of udf which calculates S is presented at following:
thread_loop_c (t,domain)
begin_c_loop(c,t)
int i=1;
C_UDMI(c,t,4)=0.0;
c_face_loop(c,t,i)
f=C_FACE(c,t,i);
tf=C_FACE_THREAD(c,t,i);
if(BOUNDARY_FACE_THREAD_P(tf)) {
BOUNDARY_FACE_GEOMETRY(f,tf,A,ds,es,A_by_es,dr0);
convection=(F_UDMI(f,tf,1)+F_UDMI(f,tf,2)/C_R(c,t))*F_FLUX(f,tf) ;
diffusion=C_UDMI(c,t,11)*A_by_es/ds*(F_T(f,tf)-C_T(c,t)); } else{
INTERIOR_FACE_GEOMETRY(f,tf,A,ds,es,a_by_es,dr0,dr 1);
if(F_C0(f,tf)==c) {
F_T_G[0]=0.5*(C_T_G(c,t)[0]+C_T_G(F_C1(f,tf),t)[0]);
F_T_G[1]=0.5*(C_T_G(c,t)[1]+C_T_G(F_C1(f,tf),t)[1]);
diffusion=0.5*(C_UDMI(c,t,11)+C_UDMI(F_C1(f,tf),t, 11))*A_by_es/ds*(C_T(F_C1(f,tf),t)-C_T(c,t));
if(F_FLUX(f,tf)>0) {
convection=C_UDMI(c,t,12)*F_FLUX(f,tf); /*method is first order upwind*/
else {
convection=C_UDMI(F_C1(f,tf),t,12)*F_FLUX(f,tf);
else {
F_T_G[0]=0.5*(C_T_G(c,t)[0]+C_T_G(F_C0(f,tf),t)[0]);
F_T_G[1]=0.5*(C_T_G(c,t)[1]+C_T_G(F_C0(f,tf),t)[1]);
diffusion=0.5*(C_UDMI(c,t,11)+C_UDMI(F_C0(f,tf),t, 11))*A_by_es/ds*(C_T(F_C0(f,tf),t)-C_T(c,t));
if(F_FLUX(f,tf)<0) {
convection=-C_UDMI(c,t,12)*F_FLUX(f,tf);
} else {
convection=-C_UDMI(F_C0(f,tf),t,12)*F_FLUX(f,tf);
C_UDMI(c,t,4)=C_UDMI(c,t,4)-diffusion+convection ;
C_UDMI(c,t,4)=C_UDMI(c,t,4)/C_VOLUME(c,t) ;
end_c_loop(c,t) }
C_UDMI(c,t,11) indicates to effective conductivity in last iterration;
C_UDMI(c,t,12) indicates to [e+P/rho] in last iteration;
F_UDMI(f,tf,1)indicates to enthalpy in face;
F_UDMI(f,tf,2)indicates to pressure in face;
C_UDMI(c,t,4) is equal to S in context .
But in any iteration I faced to S in range of -250000 to 350000 ; whereas in any iteration S should be zero . Why it happended ?
Have you a suggestion in order that I could remedy this problem ? Does fluent use another method for calculating of S ?
I am appreciated for everybody who help me in solving this problem.
Thank's.
Asghari.
