-   -   udf problem.... pls help (http://www.cfd-online.com/Forums/fluent/43286-udf-problem-pls-help.html)
anant January 10, 2007 02:11
Hi everybody, I am doing a 2D problem in which a small wedge protrudes out in Y direction from the surface while air flows over it in the X direction. I am following the UDF for the piston motion i.e One DOF equation of motion of the piston in X direction from the UDF manual (Dynamic mesh :DEFINE_CG_MOTION). I have changed the set x component of velocity to Y component by setting vel[1]= vel_prev. After I compile the UDFsuccessfully, i am unable to progress further since there is error msg . The error is Error: get_udf_function: function piston::libudf has wrong type: 39!=46. can any one help me please.
thanks a lot in advance.
sujith January 10, 2007 12:20
Re: udf problem.... pls help
wrong type: 39!=46.
make sure u are hooking it at correct location
- Sujith S Nair
anant January 11, 2007 07:01
Thank you Sujit for the advice. I corrected the hooking procedure and overcame that situation. however when i started iterating, I got into another problem of access voilation. The error msg reads.
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
I also made a simple 2D clinder and piston geometry and used the same UDF for the X direction motion. still the same access voilation error occurs. I have used the UDF which given for the 1DOF eqn of motion for Dynamic mesh in the UDF manual( chapter 4, para 4.5). I am confused as to whether I have to do anymore changes in the UDF before i use it. can u pls help me.
