Error: access: unbound variable,HELP
Old   January 15, 2007, 23:21
Default Error: access: unbound variable,HELP
sudhakar
HAI EVERY ONE I AM WORKING ON SHELL AND TUBE HEAT EXCHANGER .WHEN I AM READING MESH FILE IN FLUENT IT IS SHOWING AS FOLLOWS
: Reading "G:\sudha\2sem6.msh"... 287586 nodes.
1670 mixed wall faces, zone 4.
22278 mixed wall faces, zone 5.
1662 mixed wall faces, zone 6.
464 mixed outflow faces, zone 7.
464 mixed mass-flow-inlet faces, zone 8.
9302 mixed wall faces, zone 9.
5336 mixed wall faces, zone 10.
1878 mixed outflow faces, zone 11.
9344 mixed wall faces, zone 12.
5340 mixed wall faces, zone 13.
1878 mixed mass-flow-inlet faces, zone 14. 3242486 mixed interior faces, zone 16. 980346 tetrahedral cells, zone 2. 655801 tetrahedral cells, zone 3.
Building...
grid, Note: Separating interior zone 16 into zones 16 and 1.
default-interior -> default-interior (16) and default-interior:001 (1) Note: Separating interior zone 16 into zones 16 and 15.
default-interior -> default-interior (16) and default-interior:015 (15)
materials,
interface,
domains,
zones,
default-interior Error: access: unbound variable ---------------------------------- Error Object: phase-domain? ------------------------------
wi1
wi2 Error: access: unbound variable -------------------------------- Error Object: phase-domain? -------------------------------
wo1
wo2 Error: access: unbound variable ------------------------------- Error Object: phase-domain? --------------------------- Error: access: unbound variable ------------------------------- Error Object: phase-domain? --------------------------
cw1
cw2
cw3
cold
hot
mass-flow-inlet-14
outflow-11
mass-flow-inlet-8
outflow-7
shell conduction zones, Done. HOW TO AVOID THE ERRORS (UNDERLINED) PLEASE HELP ME,THANKS A LOT
Error: unbound variable eric FLUENT 3 November 12, 2019 09:37
ERROR : Error: access: unbound variable !! Help ! Shriram FLUENT 0 June 22, 2007 08:30
unbound domain someshwar rao FLUENT 1 April 13, 2007 09:27
Error: access: unbound variable vivek FLUENT 0 June 6, 2005 06:05
Error: access: unbound variable cfd-novice FLUENT 0 April 3, 2003 04:53
