PERIODIC
Old   January 16, 2007, 04:45
Default PERIODIC
Donia
hi,can you give me some information about periodicity especially in traslation.what 's the purpose?while peiodic does it stop iterating once we achieve the number of periodic iterations we prescribe or it can stop once we reach stable sollution? i hope you understand what i need unless i 'll try to describe the pb in details. thanks
Old   January 16, 2007, 06:23
Default Re: PERIODIC
Jack
That is to model a channel flow, for example, to simulate the flow characteristic at a point infinitely downstream. Hope this is the answer you want.
Old   January 16, 2007, 06:38
Donia
if i'm working on a long channel can i use a short one for example a half-length one and make it twice periodic?
Old   January 16, 2007, 07:02
Jack
imagine this, outlet of the the channel section is fed back to the inlet of the same section, what do you think? Isnt that when the solution converged it will represent a point at infinitely downstream?
Old   January 16, 2007, 14:24
Jonas Bredberg
Utlizing periodic boundary condition is an excellent way of reducing the necessary number of computational cells. One may in fact simulate an infinte long channel using a "2D" domain.
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 02:18
rotational periodic boundary conditions in ICEM user0314 ANSYS Meshing & Geometry 1 June 21, 2011 01:57
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 28, 2010 23:32
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap Josh ANSYS Meshing & Geometry 10 July 8, 2010 02:39
Must periodic oscillation give periodic results? zonexo Main CFD Forum 6 May 13, 2007 15:36
