operating on many volumes
Old   January 16, 2007, 05:05
Default operating on many volumes
Kasper Skriver
How do I operate on many volumes in Gambit?
I want to subtract some 120 volumes named "volume.3" ... "volume.123" from "volume.1"
How do I do that in a simple way in a journal file instead of writing all the volume names??
Is there a way to specify all volumes but two? Say I want to specify all volumes but "volume.1" and "volume.2"
Old   January 16, 2007, 05:46
Default Re: operating on many volumes
Ralf Schmidt
Hi!
there is the gambit journal, that makes it possible using many commands at once.
You write a gambit journal, the details are given in the documentation. Here are some lines, I wrote for creating many volumes from faces and rename them:
volume create stitch "f-300.930.-500_-290.930.-490" "f-300.930.-500_-290.940.-500" "f-300.930.-500_-300.940.-490" "f-300.940.-500_-290.940.-490" "f-300.930.-490_-290.940.-490" "f-290.930.-500_-290.940.-490"
volume modify "volume.1" label "v-300.930.-500_-290.940.-490"
In gambit, you have to start the journal with file-run-journal or somethink like that...
hope, it helps
Ralf
operating pressure and operating density phil FLUENT 5 November 7, 2017 17:02
Problem with Volumes Gambit Danath ANSYS 1 October 19, 2011 08:20
[GAMBIT] Connecting volumes makaero ANSYS Meshing & Geometry 4 April 15, 2010 19:18
negative grid volumes when adapting Dave FLUENT 1 August 20, 2005 13:47
union of volumes CHUBBY FLUENT 2 May 4, 2001 06:31
