January 16, 2007, 22:55 |
solar heat flux through roof
I would like to determine how much heat flux will be added to a domain by a solar load only. I have set up simple roof sections in the following ways:
1. Using a zero-thickness wall with Shell Conduction and a supplied thickness, etc. 2. Meshing the actual solid components and assigning the material properties to it. I am trying to use the solar ray tracing algorithm and am having a hard time figuring out exactly how to set it up. What surfaces do I pick to participate in solar ray tracing? Only the roof? Everything? The roof and the inlets/outlets? What post processing value should I use to get the heat flux that will be passed through the roof section. Do I look at "Total Surface Heat Flux" in the "Wall Fluxes" panel? Or is there another value to look at? I am new to solar calculations and would also like some tips on what one would typically expect for a heat flux with a solar heat flux of 1120 W/m^2 applied to the outside of a roof? Thanks for any help you can give me! |
January 17, 2007, 16:01 |
Re: solar heat flux through roof
After working with FLUENT, I figured out the problem. If you are going to use a zero-thickness wall with Shell Conduction in FLUENT 6.3.26, you need to use tri/tet cells instead of quad/hex cells.
Sign of Heat Flux at wall | Kyung | FLUENT | 2 | February 26, 2016 16:25 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
Heat Flux Wall Boundary Confusion. | Joee | FLUENT | 1 | August 21, 2010 12:20 |
Solar Heat Flux | JoHn@ | FLUENT | 3 | April 1, 2004 10:53 |
Heat Transfer Coeff. at Heat Flux Boundary | Rushyen | CFX | 6 | January 18, 2001 05:09 |
