creation of circular face in 3d rectangular model |
January 19, 2007, 07:32 |
hai to every one
i am facing problem in creating circular face in 3d rectangular prism in middle in fluent. i tried with define-surfce-quadric suface option.but i could not succede .i want to create a circular face in 3d model .please help in this direction thanks in advance sudhakar |
January 19, 2007, 10:09 |
Re: creation of circular face in 3d rectangular mo
You could define your axis of rotation as the center of the face you want to solve (Define->Boundary Conditions, and select the fluid volume, then define your axis of rotation). Then to create the face you can create an iso-surface of constant radius (Fluent will use the axis of rotation you defined for the fluid as the axis for the surface).
Hope this helps, and good luck, Jason |
Display Modes | |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 08:18 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
[ANSYS Meshing] 2D Jet Engine Model Creation in Ansys | vincentryan.s | ANSYS Meshing & Geometry | 0 | July 21, 2011 14:23 |
WARNING: non-positive face area exist. | Alan | Main CFD Forum | 4 | August 17, 2006 08:33 |
[Commercial meshers] FluentMeshToFoam Error A model face is not matched Shape detection failed | vvqf | OpenFOAM Meshing & Mesh Conversion | 2 | June 1, 2006 08:06 |
