Hamid Nabati
January 23, 2007 01:47 |
Falsh Tank with bauxite slurry
I'm going to simulate a special flash tank using Fluent software as a part of my thesis. The flash tank is used in a process line in the Alumina factory. I would like to know whether it is possible fundamentally to use Fluent for this purpose or not? the complementary informatoions are as following: 1- The raw material entering the flash tank is bauxite slurry(a mixture of milled bauxite, lime and weak caustic liquor) 2- Inlet T and P are:270 C, 5.74 Mpa 3- Flash tank pressure :4.41 Mpa
