-   -   Contours (http://www.cfd-online.com/Forums/fluent/43453-contours.html)
Sangeeta January 24, 2007 03:04
Contours
After iterating , i get temperature contours discreet. Can i know what could be the problem?
sachin January 24, 2007 03:57
Re: Contours
can you expedite what is actually contours showing?
Sachin
Sangeeta January 24, 2007 05:12
Re: Contours
No, I cant
Akshay January 24, 2007 08:22
Re: Contours
May be I can suggest you something if you could tell me what are you doing?Are you able to iterate successfully?is your solution converged?is your mass is conserved?
what i understand is, you ahve successfully iterated, and you get this as a error when you try to display contours of temperature or velocity.
Do you mean to display it as a filled temperature option?
Sangeeta January 24, 2007 12:24
Re: Contours
I am using fluent to model Inductively coupled plasma. It was sucessfully iterated and converged. Only Temp and velocity contours (filled) showd discete contours. Can i know the reason.
I dont have background of Fliud Dynamics.
Sujith January 24, 2007 16:29
Re: Contours
If the problem is getting the discrete values at each cells instead of a continuously varying contour across cells, you may not have turned on the nodal values in the display contours option.
Jason January 25, 2007 09:11
Re: Contours
Increase the number of contour ranges from 20 to 100. That'll smooth out the plot. Also make sure nodal values is selected.
Good luck, Jason
Sangeeta January 26, 2007 05:57
Re: Contours
Thanks
Sangeeta January 28, 2007 11:55
Re: Contours
I have tried clicking node values and ranges also but the problem still exits.(Coutour shows some lines and some dots)
mmacrb January 29, 2007 13:42
Re: Contours
can you send me the case and dat files so i check what is the problem
my email is bhuttathermo@yahoo.com
Jason January 30, 2007 12:21
Re: Contours
Have you turned on "filled"?
Jason
Sangeeta January 31, 2007 02:16
Re: Contours
Yes i have done that
