Udf compiling problem
the udf "builds" but it does not "load".
the following error comes up, "cannot find path" is it necessary to have C++ installed to have the udf work? does the udf need to be changed foe different versions of fluent 6.1 & 6.2? please help.. |
Re: Udf compiling problem
Maybe have the fluent running in your current directory.
keep your udf in your working directory.
I have myu UDF in Working directory itself.
so i presume, apart from having the udf in the same directory, having C++ installed is a must for the udf to compile?
The Fluent software has a builtin C++ compliler i suppose ?
Hello
Is there any source for getting 'nmake' file? because I have some problem with 'nmake' when I try to compile a udf. Thanks Ali |
