-   -   Velocity inlet calculated from Mass Flow Rate (http://www.cfd-online.com/Forums/fluent/43494-velocity-inlet-calculated-mass-flow-rate.html)
Anthony January 26, 2007 10:55
Hi everybody, I'm modelling a Hot Water Tank with a Mass Flow rate inlet of 0.0972 kg/s with an inlet diameter of 15mm. When I initialize the simulation computed from inlet, I have an X velocity of 0.00652 m/s while I'm supposed to have 0.55 m/s from hand calculation. What's wrong??
Thanks for your help
Anthony
Seeker Phil January 29, 2007 13:59
Re: Velocity inlet calculated from Mass Flow Rate
Hi Anthony, I am guessing the units for your grid are not right. Go to Grid--> Scale and make sure that you scale the grid by the correct factor to bring it to SI units. I cannot think of any other reason!
Phil
