Running on Distibuted Memory linux itanium cluster |
January 29, 2007, 01:18 |
I have been trying to run Fluent on a cluster consisting of 4 hp 64 bit hp itaniums. Each has passwordless ssh between each other node. Each once can launch Fluent and the command ssh node1 fluent works as well. From what i could tell I should run using the command "fluent -t2 -pethernet -mpi=mpich1-ssh -cnf= hostfile.hosts". This gives the following error message "-mpi option "mpich2-ssh" not supported with this hardware/interconnect". Is this not supported on itaniums? Is rsh access required for itaniums?
running out of memory in Gambit, Help!!! | ahmet | FLUENT | 19 | October 5, 2013 07:01 |
Who is running Phoenics with a cluster? | Maria Morabito | Phoenics | 2 | January 4, 2004 06:07 |
linux cluster | Johan Carlsson | Main CFD Forum | 2 | June 21, 2003 08:14 |
To Jonas: Linux Cluster | Mark Render | Main CFD Forum | 1 | June 20, 2002 05:19 |
Linux Cluster Computing | Mark Rist | Main CFD Forum | 5 | September 10, 2000 06:51 |
