udf
Old   January 24, 2007, 10:15
Default udf
Jihwan
Temp Gradient in UDF
Hi
I have a problem accessing the temperature gradient in a UDF.
I want to give temperature gradient on the 2-D wall.
(Methematical fucntion is T(x)= 30 + ( 1.5 * lxl )
I am writing using DEFINE_PROFILE.
I just following UDF manuals Ex.
But my udf file didn't warking.
I didn't know what is problem.. becuz I'm rookie on fluent.
Could anyone help me in this
*** cpp file (made by me) ***
#include "udf.h"
DEFINE_PROFILE(wall_temp,thread,index) {
real x[ND_ND];
real temp;
face_t f;
begin_f_loop(f,thread)
temp = F_T(f,thread);
F_UDMI(f,thread,0) = 30 + (1.5 * x );
if (x < 1)
x * = - 1
end_f_loop(f,t) }
Old   January 24, 2007, 15:39
Default Re: udf
Sujith
there are errors in the udf. F_UDMI(f,thread,0) is reqd. only if a user defined memory is not needed for storing some information.
begin_f_loop(f,thread) will loop over all the faces where you are hooking the udf.
get the centroid of each face using the macro F_CENTROID(x,f,thread)
u will get x,y,z coordinates as x[0],x[1],x[2]
then define your profile F_PROFILE(f,t,i) = f(x,y,z)
You may refer the documentations....
Best wishes, Sujith
Old   January 25, 2007, 00:08
Default Re: udf
Jihwan
dear Sugith
Thanks for your advice.
I'll more try again.
Can I send mail to you when I have a problen about this?
Have a nice day.
Old   January 25, 2007, 09:17
Default Re: udf
Sujith
most welcome
Old   January 29, 2007, 09:59
Default Re: udf
Jihwan
hi Sujith
I tried again..
But I failed again..
I was so confuse.
can you help me?
I made new udf file...
even though that failed interpreted.
****************************************** #include <udf.h> #include <math.h>
DEFINE_PROFILE(temp_wall,thread,position) {
real x [ND_ND];
real r,z,y;
face_t f;
F_CENTROID(x,f,thread);
r=x[1];
r=sqrt(x*x);
F_PROFILE(f,thread,position)=30.+(1.5*r);
end_f_loop(f,thread) }
Old   January 29, 2007, 10:54
Default Re: udf
Jihwan
Hi Sujith
I succeed interpreted.
But I failed the compiling..
I don't know what is problem..
************************************************** ** #include <udf.h>
real x [ND_ND];
real a,y;
face_t f;
a=x[1];
F_T(f,thread)=30.+(1.5*fabs(a));
I need your help
Old   January 29, 2007, 11:51
Default Re: udf
Sujith
What is the error message? Probly u will not be havin a recommended microsoft compiler for windows
Old   January 29, 2007, 21:08
Default Re: udf
Jihwan
Message is
I succeed interpreted. but I failed compiling..
massage aappear after clik Load button at compiling.
"pening library "Temp_wall"...
Error: open_udf_library: can't not found file.
Error Object: ()"
And I use visual c++
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
