December 27, 2010, 02:09 |
Urgent; parallel processing in fluent 12
Rep Power: 15 |
Hello every body
I want to do parallel processing in Fluent 12, but when I launch fluent 12 and choose parallel option, Fluent gives following error: Loading "D:\PROGRA~1\ANSYSI~1\v120\fluent\fluent12.0.16\li b\flprim1119.dmp" Done. Host spawning Node 0 on machine "chemeng-db7ca10" (win64). 999999: mpt_get_dot_address: warning: chemeng-db7ca10 -> 127.0.0.1. Check your system network configuration! 999999: mpt_get_dot_address: warning: chemeng-db7ca10 -> 127.0.0.1. Check your system network configuration! You can press CTRL+C to stop the startup process! WARNING: No cached password or password provided. use '-pass' or '-cache' to provide password mpid: Cannot connect to mpirun (0.0.0.0, 1126): Unknown error connect_mpirun failed What should I do? thanks for any help |
January 18, 2011, 07:51 |
NeNaD
Rep Power: 16 |
Mansureh,
which Number of Processes you setup? |
September 24, 2012, 04:26 |
i got the same problem
#3 | |
zdong
Rep Power: 14 |
September 24, 2012, 08:03 |
SANDRA BENVENUTO
Rep Power: 14 |
turn off your fire wall.
September 25, 2012, 11:12 |
shoeb khan
Rep Power: 14 |
Try to make a server machine and the other clients machines and then connect them in a lan.
Then install fluent om the server and install mpinch client on the client. Then try to run it Hope that will work. |
parallel processing Fluent 6.3.26 | ck3 | FLUENT | 6 | October 30, 2013 00:44 |
Parallel Processing on ANSYS FLUENT 12 | srr | FLUENT | 2 | April 16, 2011 14:16 |
Grid Check Fails in Parallel Processing Mode | askance | Main CFD Forum | 0 | October 20, 2010 10:11 |
Fluent Parallel Processing | Mrxlazuardin | FLUENT | 2 | April 28, 2010 07:36 |
Parallel Fluent with Mandrake | Daniel Dotta | FLUENT | 1 | May 19, 2005 15:30 |
