Home > Forums > FLUENT
Whether UDF need or not
Old   January 31, 2007, 07:35
Default Whether UDF need or not
Ranjith
How will you find out that wethere the problem hooked with UDF or not?
Old   January 31, 2007, 13:38
Default Re: Whether UDF need or not
Allan Walsh
Put a write statement in the UDF.
Old   January 31, 2007, 13:40
Ranjith
how will you find out that wether the problem hooked with UDF or not help me plz thanks
Old   February 1, 2007, 00:51
pinks
Once you have succesfully compiled and loaded, if you select the udf name in the drop down list at the desired location it is hooked. Now the question is how to understand if its executed or not. The same is said by Allan i.e. put a write statement. i.e. you can put a print command in your udf and as you proceed with solving you will the the message printed in console window. You can add the following commandin your udf. Message("I am in udf");
Thread Tools
Trackbacks are On
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
Dynamic Mesh UDF Qureshi FLUENT 1 December 2, 2009 01:27
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
