January 31, 2007, 06:35 |
Whether UDF need or not
How will you find out that wethere the problem hooked with UDF or not?
January 31, 2007, 12:38 |
Re: Whether UDF need or not
Put a write statement in the UDF.
January 31, 2007, 12:40 |
how will you find out that wether the problem hooked with UDF or not help me plz thanks
January 31, 2007, 23:51 |
Once you have succesfully compiled and loaded, if you select the udf name in the drop down list at the desired location it is hooked. Now the question is how to understand if its executed or not. The same is said by Allan i.e. put a write statement. i.e. you can put a print command in your udf and as you proceed with solving you will the the message printed in console window. You can add the following commandin your udf. Message("I am in udf");
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
