January 31, 2007, 20:41 |
Laminar flow
Dear all
Have you had any problems with laminar flow? My numerical modeling deal with lamiar flow. I just though that numerical modeling for laminar flow would be simple. But, numerical data does not match with experimental data. I do not say the data value. The trend is different. For example, imagine that temperature of number 1 sample is higer than number 2 sample. But, numerical results are opposite I have tried to match numerical data with experimental data. ( increase mesh number, change mesh , 3d dp, SIMPLE/SIMPLEC/PISO, second order momentum/pressure/energy, etc ) I couldn't. Actually, for laminiar flow, there are very few setting to change comparing to turbulent flow. Do you have any ideas? Thanks |
February 1, 2007, 03:10 |
Re: Laminar flow
I have a similar problem with laminar flow. In my case oscilations of temperature are much higher then experimantal data and similar to your case there is not much to change in the model Brgds, wabik |
February 1, 2007, 12:45 |
Re: Laminar flow
I think near wall treatment is the critical part in laminar flow modeling. I am going to do the experiment and the laminar flow too. Hope my intensive grid near the walls can help. Crossing fingers.
February 1, 2007, 14:10 |
Re: Laminar flow
Hi. Wabik
I have also a same problem.( oscilations of temperature ) In my case, as I increase mesh number, I check the temperature. When I used small number of mesh, there was no oscilations of temperature. But, at the large number of mesh, there was oscilations of temperature. I think that oscilations of temperature maybe depends on mesh number or mesh quality.( Of cousre, not always ) To match numerical data and experimental data, I try to change discretization scheme. As you can see, there are very few things to change for laminar flow. Do you have any experience to change discretization scheme as you are doing a numerical modeling? |
February 1, 2007, 14:18 |
Re: Laminar flow
Hi. kk
I hope your research go well. In my case, I also increased mesh numbers near wall. But, there was not a significant difference. I checked up to 2,600,000 mesh.. -_- So, I try to change discretization scheme so that I match numerical data with experimental data, . As you can see, there are very few things to change for laminar flow. Do you have any experience to change discretization scheme as you are doing a numerical modeling? Good luck!! |
Boundary Layer of Laminar Flow over a Flat Plate | Blasius_Pohlhausen_Crocco | Main CFD Forum | 12 | September 30, 2013 17:35 |
Can I use turbulent model to solve a laminar flow? | nikhil | FLUENT | 5 | February 1, 2011 10:42 |
How to enforce laminar flow while using k-e | Grzegorz Kondora | FLUENT | 0 | January 28, 2009 10:35 |
grid for laminar flow | kim | FLUENT | 2 | April 4, 2002 02:44 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
