Home > Forums > FLUENT
Brikman Number
Old   February 5, 2007, 03:09
Default Brikman Number
majid reza mahjoob
Hi, any can help me to define the Brikman Number in fluent?
Old   February 5, 2007, 04:24
Default Re: Brikman Number
Swarup
use custom field functions in define menu; you define Brinkman number using the buttons for operators and variables from the adjacent list of variables.
Swarup.
Old   February 5, 2007, 07:09
majid reza mahjoob
Hi Swarup thanks for your attention.how can apply the effect of amount of Brikman Number in solution of convective heat transfer by fluent? if you know please help me? mahjoob
Old   February 6, 2007, 00:21
Default Re: Bri(n)kman Number
Swarup
First, read the help manual for modeling heat transfer.
Bri(n)kman number is used to assess importance of viscous heating of a fluid (which may also be caused by wall conduction). So, it will be ususally important only for viscous fluids like polymers. It can also be important in compressible flows. It is important when it exceeds or equals unity. So, please check this first.
Then if it necessary to include it, enable viscous heating option if you are using segregated solver. If you need to use coupled solver, then viscous dissipation is included by default.
Swarup.
Old   February 6, 2007, 01:31
majid reza mahjoob
Hi Swarup I simulation the dimensionless microchannel, in the Temperature constant boundary condition in the heating the fluid, 2 problems occur: 1- in the heating Tw>Te But the dimensionless temperature of wall (tetta-w) become zero and dimensionless temperature of inlet (tetta-e) become one its mean that
Old   February 6, 2007, 01:32
majid reza mahjoob
2-in heating Brinkman Number is negative and in cooling the Brinkman Number is positive, how effect the amount of Brinkman Number in simulation dimensionless of heating
Thread Tools
Trackbacks are On
Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Mesh Utilities 41 January 17, 2013 03:43
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
BlockMeshmergePatchPairs hjasak OpenFOAM Native Meshers: blockMesh 11 August 15, 2008 07:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
