Radiation in UV reactor
Old   February 6, 2007, 11:40
Default Radiation in UV reactor
Ferdinando
Hi all, i am working with Fluent and Gambit on this problem: a disifection of waste water in a uv reactor. I am studying a 2d case (easy case). I have 4 tubes. In these tubes (made by teflon) there is water. These tube are contained in a box (reactor case). In this box there is air. External of tubes there are 4 uv lamps. The radiation has multiple domain (air--teflon--water). I want to know the distribution and the decadence of fluence in multiple domain. As i said i'm working in a simple 2d case: a rectangular box (that contain the lamp and the tube), a big circle (tube section - water domain), a little circle (uv lamp). I want use DO radiation. I have problems because i see only fluence in air domain but not in fluid domain. How is it possible? I can give some detailed images. Thank you in advance for helping.
Old   February 6, 2007, 16:43
Default Re: Radiation in UV reactor
kk
hi, I am also doing UV disinfection modeling too. But my media is air.Instead of DO model, I am using Veiw Factor distribution model. My supervisor has developed a cute UV distribute model: UVCal. BTW,Can UV@254(if you are using LP lamp) penatrate teflon? If you can send me the the diagram of the UV reactor , that will be helpful.
Old   June 4, 2020, 07:19
Talking Modeling of UV lamp
Uzu
Zeba
Uzu is on a distinguished road
I need to irradiate a parallelepipedic device where water is flowing inside with a UV lamp (254nm) on Fluent. I finished designing the geometry in question, I generated the flow. I think everything is good for the stream compared to the theory. But for the UV radiation, I don't really know how to proceed. I thought I could consider one side of my geometry as a UV source by simply adjusting its temperature. But that has nothing to do with the point I've set myself. Does anyone here have any idea what I can do? Thank you in advance.
Uzu is offline   Reply With Quote
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
Surface incident radiation Pipiola FLUENT 0 August 11, 2009 15:46
Multiphase radiation in CFX Luk_Fiz CFX 5 March 17, 2009 03:51
Radiation: definitions visatron CFX 7 January 8, 2004 15:25
Fluent incident radiation problem Michael Schwarz Main CFD Forum 0 October 21, 1999 05:56
