eddy break-up artificial flames
Hello Users,
I'm using Fluet to model wood combustion, with the eddy dissipation model for gaseous combustion HOWEVER I get flames in all the wrong places - at the edges of bluff bodies, not above the wood pile. the CFD Wiki (http://www.cfd-online.com/Wiki/Combustion) says that this is a known problem for eddy break-up models and some packeges have a way round it... but gives no details! Can anyone advise? Thanks, Hugh. |
Re: eddy break-up artificial flames
Hi Hugh,
Just a suggestion (one of many possible reasons, not necessarily correct in your particular case): is your combustion regime is "well ventilated"? i.e. is it enough oxygen around your wood pile for flame to appear there? I think I saw simulations of diffusion combustion with EBU model (but different from FLUENT CFD code) showing flame not at the fuel source (in a room), but where oxygen is available (behind window openings). Regards, Dmitriy |
Hi Dmitriy,
Yes, it is well ventilated - air coming up thorugh a bed of wood, which is devolatilising. There is a small flame at teh edge of the first piece of wood, then far far away at the trailing edge of a lip at the outlet, but not directly above teh wood as you would expect. Still confused! Hugo. |
Hugo, Sorry then - no clue. Dmitriy
