Command not working in 6.3 which worked in 6.2
Hi everybody,
I used the /solve/dual-time-iterate command in the journal file for fluent 6.2 for running an unsteady case. But when I try to run the same problem using fluent 6.3, it is now giving an error as follows: Error: eval: unbound variable Error Object: /solve/dual-time-iterate Could someone please let me know what the problem might be and how to correct it? Thanks for your help. Anindya |
Re: Command not working in 6.3 which worked in 6.2
You can try to change as this: solve dual-time-iterate
It works well in fluent6.3 in my files. By the way, do you know how to format the data file when using monitor/surface to save data? Thanks |
