-   -   Dynamic Mesh, (Define_Geom) UDF (http://www.cfd-online.com/Forums/fluent/43704-dynamic-mesh-define_geom-udf.html)
ROOZBEH February 10, 2007 19:17
Dear FLUENT 6.2 user;
Can I use define_geom function to define a time dependent geometry?
I want to model the 2D flow field around a rigid plate (or line in 2D), oscillates (in a specific angular interval) around one of its edges.
with the best regards, ROOZBEH
soe February 27, 2007 03:16
Re: Dynamic Mesh, (Define_Geom) UDF
You're modelling a rigid plate so DEFINE_GEOM is a good macro for that. You can use it to prescribe angular velocity of the rotation, so yeah the orientation will be time dependent. I don't quite get what you mean by oscillation around the edges though, that sounds like it's a 3D problem. As far as I understand DEFINE_GEOM cannot provide relative movement between nodes(ie. non-rigid body), for that you use DEFINE_GRIDMOTION. In other words DEFINE_GEOM can only change the orientaion of a dynamic zone, and not the actual shape of it.
linch August 28, 2009 05:52
Define_gridmotion
Originally Posted by soe
;139579
I can't find any Informations about DEFINE_GRIDMOTION neither in the Fluent manual nor in the internet. Could somebody please help me?
Thanks in advance!
linch August 28, 2009 08:28
Ok, it's already done.
The macro is called DEFINE_GRID_MOTION and not DEFINE_GRIDMOTION
