February 9, 2007, 05:42 |
compilation techniqes
hi cfdiens
does any one know how to create a files that require to compile the udf.(not header files)libudf...etc thanks in advance |
February 11, 2007, 06:54 |
Re: compilation techniqes
actually what u want to know be clear . U CAN udf in C taking the help of help file. it should BE COMPILE OR INTERPRETE to link with fluent. u just write udf in c and open fluent and go define ->userdefine ->function ->interpreted/compiled it may help u
February 11, 2007, 23:09 |
thaks for your reply
i have a c program.when i open the compile option there are two columns,one is source another is header files.for the source i can select the c source but wat about the headerfile? nothing is visible. thank you |
February 11, 2007, 23:29 |
hi No need to go for the header file. JUST LEAVE IT AND PROCEED OK ALL THE BEST
February 12, 2007, 03:25 |
hi i did the same but it shows like this
Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified. Error Object: () thank u |
February 12, 2007, 03:52 |
have u installed VC++ in ur sysyem properly ?
February 12, 2007, 04:02 |
ya i have installed,the case and data files are in the same directory.i am using fluent 6.1 version will this make any difference?
thank u |
February 12, 2007, 04:28 |
send ur udf , case data file to me if possible, i will check it here
February 12, 2007, 05:22 |
#9 |
ok thank u
February 12, 2007, 05:36 |
#10 |
i got ur case and data send ur UDF (only) once again . it should be in .c form
February 12, 2007, 05:51 |
#11 |
got it
February 12, 2007, 06:04 |
#12 |
u got the new one
#13 |
hi in my system same problem in coming . i had compiled udf in my system for 2d problem but not 3d one
i think their may some problem in ur udf or their may something different for 3d i dont know |
February 12, 2007, 06:07 |
#14 |
i have tried in 2d also...i thing the fluent 6.1 dont have the option to use the define_mass_transfer macro... any way thanks for suggestion
r u srenath reddy thank u |
errors during compilation and installation of OpenFOAM-1.7.x on Ubuntu 10.04 | ftec | OpenFOAM Installation | 7 | February 23, 2011 06:07 |
Compilation Order and Single Precision Issues | gocarts | OpenFOAM Bugs | 1 | October 14, 2009 17:19 |
Compilation Error when running Tutorial 2.4 | zhihuali | Siemens | 7 | April 1, 2008 07:34 |
Compilation error with uparm.f | Raghu | Siemens | 2 | May 30, 2007 02:09 |
Compilation Error.... | Arnab | Siemens | 4 | September 12, 2004 15:54 |
