error
Old   February 14, 2007, 06:12
Default error
fran
what is the reason of getting a floating point error in a 3d flow, and how do i fix it?
Old   February 14, 2007, 08:57
Default Re: error
Rizwan
there are many reasons for which u get this error. can u explain wat u r exactly trying to do?
Old   February 14, 2007, 10:27
Default Re: error
fran
i`m triyng to simulate a 3d flow from a multipart geometry. one part is fixed and the other is moving, and each one is composed by several parts as well, having enough interfaces. as solver i use unesteady and k-epsilon
Old   February 14, 2007, 10:32
Default Re: error
Rizwan
is it something related to dynamic meshing schemes? if s, im sorry i have little idea about it. Regards
Old   February 14, 2007, 12:10
Default Re: error
fran
its not related with that, but i am working in a turbine, and one part moves respect to the other. i work with moving mesh (boundary conditions->fluid->moving mesh->here i put my movement parameters), and sometimes it iterates but only 7 steps as much, and then fluent show me an error message
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
