when use 3ddp?
Old   February 20, 2007, 02:41
Default when use 3ddp?
Txema
I know that 3ddp is for a 3d mesh with a double precision,
but when is it used?? I havn't found it in help. Txema
Old   February 20, 2007, 02:53
Default Re: when use 3ddp?
Kasper Skriver
it is used when you wan't double precision, meaning higher level of accuracy in the computer round off.
It consume more ram and require more time i think. Give it a try and compare results if you want to see what the difference is!
BR
Kasper Skriver
Old   February 20, 2007, 03:28
sam
what about the using dp on 64 system and windows. As indicated by joans larrson(in his thesis) (Sys Admin of cfd-online)
Old   February 21, 2007, 16:11
Razvan
Double-precision solvers are extremely useful when dealing with very sensitive analisys like aerodynamic drag prediction, multiphase systems, pollutant formation in very small fractions in multi-species+reactions in combustion systems, porous media with high resistance coefficients on highly skewed grids, an so on.
One very important thing to know: double precision solvers on 64-bit machines (and 64-bit executables, of course) are much more easily handled than on 32-bit machines (almost same memory requirements and more important, very little difference on execution times!). So don't aviod using them if you have Opterons or 64-bit Xeons.
Razvan
parallel mode failure in 3ddp but not in 2ddp ak6g08 FLUENT 1 September 22, 2009 06:56
parallel mode failure in 3ddp but not in 2ddp ak6g08 Fluent UDF and Scheme Programming 0 September 22, 2009 06:16
Parallel processing with 3ddp Error Kartik FLUENT 0 February 20, 2009 14:57
about 3ddp &3d zwdi FLUENT 2 April 18, 2004 14:36
2d,2ddp,3d,or 3ddp sean FLUENT 2 March 26, 2001 07:19
