hyraulic flume flowtank design
Old   February 13, 2007, 11:57
Default hyraulic flume flowtank design
Lindsay
hi everyone.
I'm involved with the design of a flowtank for a new hydraulic flume for Aberdeen University as part of my masters thesis. the flume is to be used for various hydraulic studies in the future such as the modelling of weir flow etc.
this requires single phase water flow (up to 200 l/s) out of a pipe, into a large open (two phase) tank. the tank then tapers down to the entrance to the hydraulic flume which should produce as smooth a flow and free surface as possible.
can anyone suggest any details of the model i should choose for accuracy as there seems to be several options which would work...? i'm a complete beginner...
I'm using so far: VOF, 3d, air (primary) and water (secondary) phases, etc.
thanks very much for any help you can give me, cheers
Old   February 13, 2007, 14:18
Default Re: hyraulic flume flowtank design
Ed
What are the respective sizes of the component geometries, and what do you want to learn from the model?
My initial comment is that you probably have a strong jet exiting the pipe into the tank, which can be challenging and time consuming to model with two-phase VOF methods.
Old   February 15, 2007, 08:10
lindsay
the model is to test two or three different geometries for the flowtank, so the most effective one at reducing the turbulence, or at least breaking up the large, long-term eddy structures can be selected for construction.
eventually the geometry will include baffles and a honeycomb flow straightener to get the "uniform" section of flow in the flume as large as possible, but initially i just need to get the model to work...
the flume is around 20m long, 1.2m wide and around 1m high. the flowtank at the entrance can be anything up to around 2.5m wide, 2m deep and 2m long...
Old   February 21, 2007, 12:15
lindsay
anyone have any suggetions? please...?
Outlet boundary condition for wave flume with interFoam solver Arnoldinho OpenFOAM 9 July 10, 2018 05:15
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
JOB: Sr. Thermal/Mechanical Design Engineer Dee Dee Dial Main CFD Forum 0 April 1, 2003 18:49
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
CFD - Trends and Perspectives Jonas Larsson Main CFD Forum 16 August 7, 1998 16:27
