February 19, 2007, 04:54 |
TECPLOT file data format Plz Explain
Hi all,
Can anyone tell me what the various numbers stand for or what is the sequence of numbers in the Tecplot file once FLUENT Exports it. The Background to shed more light I've run a case for external Flow over a wing. Now i've exported the results (pressure distribution on wing) from FLUENT in Tecplot format. I need to calculate spanwise the lift for 10cm sections from wing root inboard to outboard. I'm planning to write a prog in MATLAB or C to do this. Now to read in the TECPLOT file i need to understand what the sequence of nos in the tecplot format stand for, can anyone give me a link or a primer on this. THnx, Flyboy |
February 21, 2007, 08:50 |
Re: TECPLOT file data format Plz Explain
Hi I think you can do that from plot panel choose the surface and write the data to file the file generated will have two columns the first is the curve length the second will be the function you select from plot panel then from matlab do all u need. i hope this useful Khairy-Egypt
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
