February 13, 2007, 18:08 |
Where is the " VELOCITY-INLET" option?
When using the Gambit(ver2.1.6) to generate the grid for FUENT5.0/6.0, why I can not find the option of VELOCITY-INLET?
Could you explain WHY? |
February 13, 2007, 18:21 |
Re: Where is the " VELOCITY-INLET" option?
if you have selected the solver properly, then the option is in the bottom of the list and you can not properly see becuase some part of the list may not be visible because of taskbar of computer at the bottom. (just guessing).
February 13, 2007, 19:50 |
Hi,Zxaar,
Sorry. you are right. Now I got it. Thanks. |
February 13, 2007, 19:55 |
The velocity inlet at the bottom of the list , actually irritates me also just for the same reason that I have to put the task bar to autohide for it. This is irritating but couldn't help.
February 13, 2007, 22:39 |
instead of auto hiding u can do it this way, just select any other boundary condition (say pressure inlet) and again click the boundary condition, this tym u will see that the velocity inlet is visible.
February 14, 2007, 01:37 |
yes agreed with Rizwan
February 14, 2007, 18:04 |
I have this problem too.is there any better way out? can we change the setting of the monitor? I really don't know how to deal with the simulated X-window system.
February 15, 2007, 15:25 |
February 15, 2007, 16:36 |
#9 |
I agree with Rizwan and his method is sufficiently simple. Here I just want to add one point. When selecting the other TYPE of boudary condition, please try the lowest (or lower) one, then the VEOCITY-INLET will be visible. However, if you select the toppest one like AXIS, you might still not be able to find the VEOCITY-INLET option.
In summary, two steps: (1)try firstly the other boundary condition at "the lowest option" you could reach at current operation status; (2) switch to the VEOCITY-INLET which you are looking for. I think other techiques are not very neceesary. However, we have reason to request the Gambit company to improve this inconvenience and to make it natural from custom utilization viewpoint. Good luck, and thank you again,zxaar and Rizwan. |
February 15, 2007, 22:59 |
#10 |
Regards good luck for ur work frenk
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 21:25 |
transient simulation of a rotating rectangle | icesniffer | CFX | 1 | August 8, 2009 07:25 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
Single Bubble | Gerrit Senger | CFX | 4 | March 12, 2007 16:29 |
about compresive phase | James | CFX | 10 | September 12, 2006 03:16 |
