Home > Forums > FLUENT
two fluids two temperature
Old   February 15, 2007, 12:29
Default two fluids two temperature
Can you help me withthis. Fluent 6.2.16; VOF model. solver segregated, heat and mass transfer udf`s, two zones not seperated from each other (something like a container with water - top is open, bottom is heated). How to set up a diferent temperature for water and diferent temperature for air? (I`m using adopting metod to set up a water in bottom part of container and air in upper part).
Please answer me ))
Old   February 15, 2007, 16:17
Default Re: two fluids two temperature
Once u have adapted the region and patched the water in bottom, u can patch temperature also from the same panel. patching temp to individual phases is no different to patching volume.
Regards Hope this helps
Old   February 17, 2007, 03:56
thank you very much Rizwan.
Thread Tools
Trackbacks are On
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 10 March 5, 2015 07:57
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Bulk temperature Tf is obtained from total or static temperature? NPU_conanxie FLUENT 0 March 30, 2011 05:56
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 17:31
Heat Exchanger Fluids Lack Temperature Difference justinF FLUENT 2 July 11, 2007 22:55
