January 26, 2007, 10:01 |
Udf compiling problem
the udf "builds" but it does not "load".
the following error comes up, "cannot find path" is it necessary to have C++ installed to have the udf work? does the udf need to be changed foe different versions of fluent 6.1 & 6.2? please help.. |
January 26, 2007, 13:11 |
Re: Udf compiling problem
Maybe have the fluent running in your current directory.
January 29, 2007, 09:00 |
keep your udf in your working directory.
January 31, 2007, 01:35 |
I have myu UDF in Working directory itself.
January 31, 2007, 07:57 |
so i presume, apart from having the udf in the same directory, having C++ installed is a must for the udf to compile?
February 10, 2007, 01:29 |
The Fluent software has a builtin C++ compliler i suppose ?
February 15, 2007, 13:19 |
Hello
Is there any source for getting 'nmake' file? because I have some problem with 'nmake' when I try to compile a udf. Thanks Ali |
Display Modes | |
About UDF compiling issues: 'nmake' | Haoyin Shan | Fluent UDF and Scheme Programming | 15 | November 4, 2019 18:05 |
A problem about 'printf' and 'Message' in UDF. | LICH | Fluent UDF and Scheme Programming | 2 | May 2, 2013 02:45 |
what's the problem with my udf | zzyan | FLUENT | 0 | November 4, 2010 03:56 |
HELP! Problem compiling UDF function | Syrakus | FLUENT | 6 | April 7, 2006 10:48 |
UDF compiling problem for 3D simulation | Marijo | FLUENT | 1 | March 28, 2006 03:21 |
