Particle Track
Old   February 19, 2007, 12:26
Default Particle Track
Domenico
Hi, All
I want to generate a particle track file with the Discrete Phase Approach in FLUENT.
However, my computational domain is quite big and the particle track file that is being generated is too heavy.
Is there a way to write the particle track file only for a portion of my reactor?
Second question is: how can I make sure that the particle tracks are mass-flow weigthed? Is there a way I could display the particle distribution over a cross section and compare with velocity contour?
Thanks!
Domenico
Old   February 19, 2007, 15:15
Default Re: Particle Track
Sujith
You can use the report-->discrete phase to write particle tracks on a particular region, surface.
DPM concentration contour on the post processing surface on a surface will give an idea about the particle distribution
Old   February 19, 2007, 18:56
Domenico
Hi Sujith, thanks for your kind reply. Could you elaborate more on it?
Let me see if I have understood correctly. If I want to write particle track only in a subdomain, should I split my volume in Gambit and define different regions, isn't it?
As far as particle density is concerned, can I map and countour the particle density that hit a target surface which is cross-to-flow? If so, should define it as interior?
Thanks so much in advance,
Domenico
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
How to perform a particle track in CFX(10) post? Jordan CFX 2 September 28, 2006 12:03
Particle track James Bewley CFX 0 April 28, 2006 06:04
Particle track files Sankalp CFX 1 August 25, 2004 23:25
Particle track and digit after decimal point Sumon CFX 0 May 15, 2003 22:33
