February 16, 2007, 11:12 |
species mass source in porous media ?
Hi ,
I have 2D case : cylinder (porous media) which is in a much bigger Control volume(non porous) (flow is from inlet to outlet,...). This cylinder is acting like a sink of species. When I am running a simulation WITHOUT removing specie in this 2D cylinder NON POROUS media and another as a POROUS media : In both cases I have the same species mass fraction,VOLUME Integrale,Vol Avg, Mass Int and Mass Avg in this 2D cylinder zones (porous or Non porous). To remove a certain amount of specie (in the cylinder) ,I use a UDF(DEFINE_SOURCE) with Si = Mass of specie in cell(i)/ SUM(vol cell(i)). A)If the cylinder is NonPorous : Non prob. B)If the cylinder is Porous : There is a Prob : Even though , species have same mass fractions(Porous /non porous) , there is less Species avalaible (less flow rate ) in the cylinder(in the non porous case) : and so there is the not the same amount left in both Cases (less in the porous case). Q: How this Si (source term) is linked to the local mass flow rate in a cell i ? ; How to solve this problem then ?. Thanks for any help |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Add source term in species equation | zhou1 | FLUENT | 1 | October 21, 2003 06:28 |
mass transfer in porous media?? | yee wan | FLUENT | 0 | December 23, 2002 20:39 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 03:43 |
