Home > Forums > FLUENT
Language question
Old   February 19, 2007, 00:19
Default Language question
HSeldon
Hi, I´m dealing with the In-Cylinder model and I can´t figure what the "Piston Stroke cutoff" is. I´m not an english native speaker, as you can see Just explain me what it is or what it does to translate the idea to the spanish.
Thank you!
Old   February 20, 2007, 13:57
Default Re: Language question
Ness
Pues mirando el siginificado exacto de cutoff, es "límite, tope", literalmente es el tope de la carrera del pistón. Creo que en Fluent, por lo que he podido curiosear, viene a ser la distancia entre el tope del cilindro (zona de válvulas) y el pistón cuando está en el punto muerto superior; o, dicho de otra forma, la altura de la cámara de combustión.
Regards ;-)
Old   February 20, 2007, 14:23
HSeldon
Perfecto! muchas gracias Ness! Es bueno leer un poco de español en este foro
Saludos desde Argentina.
Thread Tools
Trackbacks are On
Comparison between C/C++ and Fortran? rick Main CFD Forum 45 September 6, 2011 00:52
Additional Command Language -in Workbench! Elvira_Coot CFX 11 July 14, 2011 01:32
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 16:26
Question about Table applicaiton. universez OpenFOAM Running, Solving & CFD 0 January 12, 2010 21:31
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
