February 14, 2007, 12:47 |
how to display the stream line
hallo, everyone,
I have a problem with displaying the stream line in 2D. I know, I can use the "stream function" in "Contours" to display the stream line. But the maximum of the level is 100. But this refers to the whole region Is there anyone know, how can I disply it in a certain region more exactly, i.e. near the wall? |
February 21, 2007, 08:54 |
Re: how to display the stream line
Hi from contour panel uncheck auto rang check clip to range write down the max and min value of stream functiom say if its range 0-->10 you select say 0-->1
i hope these useful Khairy-Egypt |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
