February 15, 2007, 04:09 |
energy equation solution
hi i have a converged solution of heat transfer through different fluid and solid.but in have not correctly solved energy equations in the solutions.can anybody help me
February 15, 2007, 06:13 |
Re: energy equation solution
Please try to change:
Define->models->solver->gradient option to Green-Gauss node based Or Least Squares cell based Do you solve system with or without chemical reaction? Which version of Fluent do you use? best regards Nicoslaw |
February 20, 2007, 06:01 |
yes i have already node based and i am not using chemical reaction and my fluent is 6.2 . i have another question for complete solution of energy equations i solved energy and flow equations sepraetly alongwith turbulence. can you tell me that whether it is preferable to solve flow equation first than energy equation
Display Modes | |
Convergence problem of the energy equation | Woo Meng Wai | FLUENT | 2 | May 13, 2008 04:06 |
Coupling between momentum and energy equation | Mattia | FLUENT | 0 | October 26, 2007 09:02 |
SIMPLE and energy equation convergence | Fabio | Main CFD Forum | 0 | June 1, 2007 07:06 |
How to discretize of energy equation ?? | Asghari | FLUENT | 0 | October 12, 2006 09:06 |
Energy equation convergence problem | Reza | Main CFD Forum | 0 | August 27, 2003 14:09 |
