Problems compiling UDFs under SuSE 10.2
I get the following error when compiling a UDF under SuSE 10.2, x86-64: sg_ke.h:44: error: expected ')' before 'const' The error points to sg_ke.h which is located in the fluent src directory. With SuSE 10.1, x86, the UDF compiles ok. Any suggestions? /G |
Re: Problems compiling UDFs under SuSE 10.2
Problem solved.
It was connected to which makefile was being used. Using a makefile generated for an x86 system on an x86-64 system proved to be the problem. /G |
| All times are GMT -4. The time now is 09:16. |
