Home > Forums > FLUENT
2D import from STP to Gambit: ACIS Error 1015
Old   February 22, 2007, 01:43
Default 2D import from STP to Gambit: ACIS Error 1015
Jonathan
I'm doing a 2D analysis of design work.
I tried to draw the 2D surface in XY plane, in Pro-E and converted it to STEP.. then I imported STEP to GAMBIT...
It shows me an Error...
ACIS Error 1015: Access Violation.
I tried IGES too with same result.
What is it? and Why it happens. can anyone suggest an alternative.
Is that a problem with the way I exported.
Is it not possible to import only 2D surfaces to GAMBIT.
Plz help... Thnx a lot...
Old   February 22, 2007, 12:49
Default Re: 2D import from STP to Gambit: ACIS Error 1015
KC
I've noticed something rather odd with Gambit and directory names - if you try and import/load/save files which have a long absolute filename then it tends to throw a wobbler with that kind of an error message.
Solution for this is to set the working directory closer to where the file you're importing is, or work closer to the directory root. I have a feeling that it has a 128 character limit for filenames including the directory the file is in, or something similar to that.
Old   September 16, 2009, 07:42
Default that's it
Aki
wu7jian is on a distinguished road
Originally Posted by KC
;139440
I couldn't agree more.Same problme showed before.
wu7jian is offline   Reply With Quote
Old   January 17, 2011, 04:49
Default i have same trouble
juli fajar sasmara
dewa is on a distinguished road
who can help us..
dewa is offline   Reply With Quote
Old   January 17, 2011, 06:56
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Are you sure you can generate 2d geometries with proE?
Are you not talking about sketch, instead? (or sheetmetal)
As far as I know proE generates 3d volumes.
So create your 2d sketch and extrude it for having a volume, then export step file. In gambit import the step file, delete the volume imported, but keep lower entities. Delete all the surfaces you don't need
But if you really have 2d surface (I mean *.prt), I am interessted in the way you generated it.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Thread Tools
Trackbacks are On
Gambit Import error GUEST FLUENT 6 February 19, 2012 21:53
SketchUp 3D model import to Gambit or Fluent Steve Johnson FLUENT 0 February 8, 2009 15:21
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
How to Import 3D objects from Pro-Engineer to Gambit? Tomb FLUENT 3 July 5, 2000 12:12
Autocad import into Gambit Paul Main CFD Forum 5 July 12, 1999 04:19
