Home > Forums > FLUENT
Zero Coefficient of Lift Problem
Old   February 25, 2007, 12:48
Default Zero Coefficient of Lift Problem
MH
Hi, I'm testing an airfoil at small angles of attack (alpha = 1,2,3,4,5) inside a antisymmetric tunnel, with the inlet 4D upstream from foil, outlet 8D downstream. I specify the proper reference variables and set up the force monitors to monitor lift and drag (with the proper force vectors), however in my results my lift coefficient is consistently equal to zero while I get non-zero results for the drag coefficient (I plot the calculated lift coefficient along the iterations and it stays zero).
I get a zero lift coefficient regardless of whether I run a steady analysis with inviscid, laminar, or turbulent models.
I do get non-zero lift coefficients when I did the analysis of the foil with farfield boundaries.
Do you know what the problem may be?
Thanks for any help you can offer.
MH
Thread Tools
Trackbacks are On
lift coefficient morteza08 Main CFD Forum 4 November 24, 2011 05:51
lift coefficient from Ferrari Testarossa mp199 Main CFD Forum 0 August 31, 2011 03:02
Fluent Good Lift coefficient BAD drag coefficient Rif Main CFD Forum 4 March 9, 2010 11:52
The lift force coefficient in bubbly flow Kai Yan Main CFD Forum 1 November 4, 2008 14:54
Plotting of lift coefficient vs angle of attack?? John Main CFD Forum 1 August 18, 2003 09:31
