Run time error
hi, when i run case/data through fluent it give error as FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
kindly let me know the reason for this, even though i changed the case/data by naming it with new name. Thank you, chakradhar |
Re: Run time error
Hi
I also got this error many times. Does anyone know what causes this error? Thanks, Shanti |
