Obtaining Nu result from internal fin channel
Old   March 1, 2007, 09:06
Default Obtaining Nu result from internal fin channel
andrew
I got a problem obtaining Nusselt number data from an internal fin channel...i have used line and rake surface (outer surface) to obtained the data from a 3D rectangular channel...however the results that i have obtained does not coincide with the theory or a specific trend...i am not sure whether the approach that i am using is right...i hope some of u could share some light to this problem...cheers
Old   March 1, 2007, 09:26
Default Re: Obtaining Nu result from internal fin channel
lee
Nu=fn(h)
Check heat transfer coefficient that you are using. If I am right, there should be different heat transfer coefficient in FLUENT, such as surface or local heat transfer coefficient.
Most of theories use heat transfer cofficent which is based on bulk heat transfer coefficient.
Old   March 1, 2007, 21:38
andrew
Thank you lee for u r quick reply..the heat transfer coefficient that is specify in fluent is surface heat transfer coefficient..which has the formula of
heff=q/(Twall-Tref)
1) What my concern is the Twall temperature that Fluent is picking...it is corresponding to each wall node temperature in the line/rake surface that i have specify?
2) Can surface integral option be used for a line/rake surface?
Open Channel Flow ElanMorin FLUENT 4 February 25, 2015 16:26
decomposePar change the result? MrFuglsang OpenFOAM Running, Solving & CFD 1 May 30, 2011 05:58
The problem of inner iteration when calling the subroutine guoxj CFX 18 October 23, 2010 20:37
how to define bc for circular tube having internal tappered fin cadcamvijay FLUENT 0 March 19, 2009 02:03
Why wallGradU result is different from dudy in the smooth channel bed xiuying OpenFOAM Running, Solving & CFD 12 March 2, 2009 07:58
