March 7, 2007, 05:26 |
Rosin Rammler Distribution
I want to inject particles in my continous phase. I`m using the surface injection, the particle-sizes should apply to a certain distribution. I calculated the spread factor of my distribution for the rosin rammler method according to the manual. But when I look at the results the distribution shows a uniform shape. The diameter have a linear size distribution between the minimum and maximum value i set, but they are not disributed in the way I want (rosin rammler). In my opinion the diameters released from each surface cell should be disributed with the spread factor I set. But they are sized linear between the min and max value I set. So whats wrong with it? Thank you for your efforts Andi |
March 7, 2007, 10:56 |
Re: Rosin Rammler Distribution
Hi Andi, Have you looked at the mass fractions of the different droplet sizes as well? The Rosin-Rammler distribution is a combination of droplet diamter and mass fraction above that diameter. So you might see the diamter distribution as linear, but the fractions of different sized droplets might be more accurate. - Phil
TAB (Taylor Analogy Breakup) Model | Zi-Wei Chiou | Main CFD Forum | 15 | December 19, 2023 09:27 |
Rosin Rammler Distribution | mystix | OpenFOAM Running, Solving & CFD | 10 | February 11, 2021 05:23 |
rossin rammler distribution in DPM | hendar_k | FLUENT | 0 | May 23, 2011 03:18 |
maintaining a logarithmic velocity distribution | Morten Andersen | CFX | 1 | January 8, 2007 11:37 |
DPM-Rosin Rammler distribution -CV probleme | olivier | FLUENT | 2 | August 8, 2001 12:13 |
