March 2, 2007, 13:18 |
Turbulence set-up question
Hi I have a very simple geometry, a rectangular one with one inlet and an outlet. The fluid is air. I want to model turbulence. can u suggest which model. I was thinking standard k-e?? Are the default model constants sufficient or i should re-calculate? Also at the inlet, the values of k and e are 1? How do i find the right values for my problem? I know the velocity at the inlet. What other parameters should i consider while setting up?
March 2, 2007, 17:49 |
Re: Turbulence set-up question
why don't you use LES if you geometry is simple and small, you just worry about the y+ only , and let the solver to do the rest. I am using LES for my duct pipe reactor now.
March 2, 2007, 17:59 |
Whats LES? How do i set it in fluent?
Instalation on ubuntu 710 | basilwatson | OpenFOAM Installation | 17 | March 16, 2012 20:16 |
Question on Turbulence Intensity | Eric | FLUENT | 1 | March 7, 2012 04:30 |
question about a droplet set | zhangkaiyu | FLUENT | 0 | March 7, 2011 19:50 |
Naive question about turbulence and LES | Renato | Main CFD Forum | 1 | October 4, 2005 23:01 |
some question about turbulence | Tom,L. | Main CFD Forum | 7 | December 14, 2002 08:47 |
