March 7, 2007, 04:00 |
Wall-wall shadow
Hi!
I have read in the fluent documentation that when a wall BC has got fluid at the both sides, it is automatically created a shadow zone. The fact is that I'm running a simulation over flat disk but the typical value of Cd 1.17 is not appearing. Cd over the disk is 0.7 aprox. and, over the shadow, 0.8. So summing up this terms 1.5. I donīt get the 1.17 right value. Why do I get different results for the shadow? Have the shadow got influence in the case? What may I be doing bad? I think this case is known enough so you got any suggestion. THanks in advance! |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
wall shadow | amar | FLUENT | 1 | February 5, 2010 06:07 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
