transient velocity for wall:UDF or Profile
Old   March 1, 2007, 11:51
Default transient velocity for wall:UDF or Profile
Modisa
I would like to know how it would be possible to define a transient velocity for the wall?
Thanks
Old   March 1, 2007, 13:49
Default Re: transient velocity for wall:UDF or Profile
Sujith
yea..
you can give a velocity profile to the wall(DEFINE_PROFILE); where the profile is a function of flow time(CURRENT_TIME)
profile = f(CURRENT_TIME)
Old   March 1, 2007, 19:29
Modisa
Hi Sujith,
Thank you for your quick response. The translational movement could be modeled by both profile and UDF. My problem is that my walls have both rotational and translational movements as a function of time. What is your suggestion for that?
Thanks
Old   March 6, 2007, 09:47
eos
hi, i am working on the same thing as well rotational movement can be also done by cg_motion udf (i did iti for both tranlating and rotating body depending on time) but i am still working on the wall velocity calculations depending on the translational and rotational movements does anybody know how to set the velocity components depending on the node positions and the variables calculated in cg_motion udf? sorry i could not answer but instead ask new questions but thanks anyway
Old   March 6, 2007, 23:30
Modisa
Hi, Could you please explain your question more. Do you mean each node of your geometry has a specific velocity?
Old   March 7, 2007, 07:30
eos
hi, as i said the the mesh is moved by the rotational and translational motion. i defined this mechanism via cg but still i can't be sure of the wall velocity. the other users using fluent say that if you hook the cg motion to wall and fluid both then the wall velocity should be adjusted as it should be. (you know the velocity will have both x and y components due to rotation) that's the problem using define_cg_motion is enough to employ the velocities at the wall? thanks four your concern
Transient profile boundary conditions dladd CFX 10 June 10, 2022 07:24
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
transient velocity profile with experimental data Janneke FLUENT 3 August 19, 2008 10:11
LES Near-Wall Velocity Profile Alex May FLUENT 2 June 12, 2008 12:36
problem with velocity inlet profile file Duncan FLUENT 3 November 21, 2005 07:28
