About the Contact Angle
Old   March 5, 2007, 10:36
Default About the Contact Angle
Flora
Hallo, everyone! I have meet a problem in my project. I hope sb. can help me about it! In my experiment, there is a steel plate on which water flows as a film.At the same time,there are also the steel supports on both sides to avoid the water coming out from sides. My aim is to investigat the film breakup conditions,such as the critical liquid flow rate. So in my simulation, I defined contact angle at the plate and both sides. From theory, it should be with the decrease of contact angle, the water will be easier to be a film! But I found that under the same conditions except for the contact angle, the film would be keep a closed film when Contact angle equals to 80 degree, While it would be breakup when Contact angle equals to 70 degree. Who can tell me what the matter is? How could I interpret this phynomenon?
Thank you very much!
Old   March 6, 2007, 07:09
Default Re: About the Contact Angle
Flora
Hallo,everyone! Can you understand my problem? Who can help me to interpret it?
Old   March 8, 2007, 02:07
Flora
Hallo, I am afraid I have not make it clear to you. Can you understand it? Who can give me the suggestion? Thank you!
Dynamic contact angle rmousavibt Fluent UDF and Scheme Programming 12 October 31, 2021 22:38
InterFoam contact angle JoaoMiranda OpenFOAM Running, Solving & CFD 7 October 20, 2016 06:27
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 13:58
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Theoretical background of formula for dynamic contact angle in interfoam sebastian_vogl OpenFOAM Running, Solving & CFD 3 June 22, 2009 12:25
